legnano
Hello, everyone.
I preferred to open a new discussion though the subject is already dealt with in: http://www.cad3d.it/forum1/showthread.php?p=175685#post175685 where I wrote but I had no answer (probably because the discussion is dated).
summarizing the problem, I need a shared design between two cad stations in one of which is located the physical hard disk contain the workspace. wanting to open the project from the remote station appears the path of the workspace marked in red and the error message I attach.
I ask you politely if the procedure I set for sharing is not correct or is to set up some setting for sharing the workspace.
thanks in advance.
the wood
thanks in advance.
the wood
