design lines in bookshelf styles
  • Thread starter Thread starter Giancesa
Giancesa
Hello
I should change the display thickness of some lines, like the breaking line of a detail view, and others, but I struggle to understand what the exact name and autodesk gives to that well-defined line. by chance there is a table, or other where you can understand the name of the line corresponding to what actually appears on the drawing. Thank you.
open the table and go to the annotation card. select the line that interests you and controls at the top right (group format) the membership layer and the style that is adopted to generate that line. at this point you can change layer thickness and/or style.
Two questions: how do I make sure that a line is always with that representation? is it better to do it in the template or go to bookshelf styles? I hope the first because for me it is always a mess to change styles.
There are lines that are not editable, for example that of breaking a view in detail, how do I do in this case?linea rottura.webp
