design of pulleys and belts
  • Thread starter Thread starter J ax
J ax
Hello, I looked on the drawing book of machines but found nothing about it: I have to draw the front view of 2 trapezoidal pulleys wrapped by a trapezoidal belt.
My doubts are:
1) Do I need to design the primitive diameter? If so, with a mixed end line?
2) how do I draw the belt?
I looked around but I didn't find anything
in the sites of builders, for example clavals, queen... find the manuals of the straps and almost certainly there are also the representations you look for.
I've got the paperwork, a little dated, and I'm here.
on queen I found only chains and on clavals I found only the designs of single pulleys in section so no frontal view with ungrained belt
you must also draw the primitive for the wheel. if you have to represent 2 wheels and the assembled strap you will design the primitives (-.-.-.-) and the primitive on the belt.
Save. here.; page 49 figure 4.
it is not necessary to draw also teeth, if you just want to be cool if they make 2/3
You're right about the queen, I'm confused with the poggi.
