leonardo000333
Yes, but as data I have speed at regime and the final one, I miss both time and acceleration... I have two unknowns in an equation or not?
You know the speed.Yes, but as data I have speed at regime and the final one, I miss both time and acceleration... I have two unknowns in an equation or not?
However making the stops with precision variable load is a nice casino because it would be necessary to calculate the couple that serves on each trip....and to do it or you know how much loads or you have to have load cells on the cart....poi make the "recept" in the plc.If it is so that you don't complicate your life, apply a flyer at the entrance of the reducer and turn!!ok it is too complicated for my application, what I do not understand is if space and time I imposed them...after in the relay will be really like this? ? '
Anyway I thought it was easier and as the engine will be operated and turned off manually maybe I should think of a different system to move this cart.
One thing that had come to my mind is, since I have low friction with the linear guides, I could put two winches one to the right and one to the left of the cart, when I have to move it on one side turn a winch when I have to let it go on the other side I release a veracello and I use the other even if it is more Moroccan. (obviously manual winches
three questions:ok it is too complicated for my application, what I do not understand is if space and time I imposed them...after in the relay will be really like this? ? '
I'm sorry, but I'd like to throw away my head by reading this post... I'm sure you're looking for luck with the bear's skin...no boss, no business, my first project without a match iva, no security only the hope that it will be accepted and financed. If I put the flyer on the reducer can be a good idea but still I have the inertia then to fight.
I thought to put a driving system like what's in the screw lathe trapeze even though this way would not stop instantly
You don't have to disconnect anything....it's not a bomb....when you slowed down leftovers at low speed and you stop in place by pairing the engine up to zero speed, insert the electric brake controlled separately and then current to the engine.I understand perfectly, I'm thinking as an alternative to disconnecting the pinion from the rack at the time of the stop so he stops when he wants and does not transmit the bike
is the unconsciousness of youth....but as the first project, something with less risk of harming?
If you use a two-winding engine you have to have all double switches, both in one sense and in the other....it is more than having an inverter to be able to program completely flexible. However you need an inverter... you can't go straight.alternatively I could use a two-speed motor with 2 n different poles, when I miss 20mm step to reduced speed
we started from 30m/min and we went down to 15m/min....but here if we go hand crank we make 1m/min. You know, dear leonardo, we're talking about different things?I still don't know if he can move it manually with a flyer on the gearbox, the speed will be very low, and so the inertias, we're talking about different planets.
I talk about the age of stone and mechanicsmg speaks of a lunar rocket! What's good at the end?
