design with autocad and make with inventor
  • Thread starter Thread starter sandro1274
sandro1274
Hello everyone, I used autocad even if for work needs I learned (from self-taught..)inventor
now I have to resume the good old autocad (version 2011) because they asked me for a collaboration in the building field, namely:
take seedlings of houses to be restored, extruder them and make them as much as possible, depending on the pre-restoration sale.
my question is the following: can I draw with autocad and use inventor only and exclusively for rendering? .. seen that the inventor's rendering is undoubtedly better.
or what other method would be more appropriate to have an optimal rendering by drawing with autocad 2011? ?
I don't know if you can do it.
I would follow this path, or work directly on inventor.
opens a new "crash"
under "insert" is acad
import the seedlings and work there directly.
then you can do a myriad of other things to render. . .
the rendering engine is the same. you're probably not able to make with autocad...
http://www.autodesk.com/products/showcase/overviewor
http://www.autodesk.com/products/3ds-max/overview
I think so! Unfortunately with autocad I never had the need to make it contrary to inventor...thanks guys for answers and thanks tristan x links.ciao
