Andrea - Overcam
no, but believe me is not a problem (unless work associated with pieces like screw, hole, dice associated with each other).
I'll explain. in spaceclaim there is no trace of particular processes such as sunshades, pockets or other in the structure tree (similar to your features tree, but that shows the list of present geometries, components, solids, surfaces, curves). are part of the geometry and if I want to change the use of the 2d sketch, the drag, or move it. to suppress everything you told me is enough to press the "fill" button instead. I can fill holes, sunshades, pockets, bevels, fittings, extrusions/protusions, sunshades, and all that "complicates" geometry. I can also select a hole and automatically select all equal holes (see figure).
nothing special, but it also works with an imported model, like a step of which we have no history... That's where she's holding a feature based.
only exceptions to this (of all not necessary, but they have inserted them for the very affectionate ones) are the particular holes (displaced, blind, threaded) and the processing on the sheet as forms of punches (soles, grids, pockets) and edges worked (smusses, grooves, fittings), which in figure you see colored because editable not with drag, but changing the properties of the old working (but I remain better).
nothing special, but it also works with an imported model, like a step of which we have no history... That's where she's holding a feature based.only exceptions to this (of all not necessary, but they have inserted them for the very affectionate ones) are the particular holes (displaced, blind, threaded) and the processing on the sheet as forms of punches (soles, grids, pockets) and edges worked (smusses, grooves, fittings), which in figure you see colored because editable not with drag, but changing the properties of the old working (but I remain better).
