design without cart
  • Thread starter Thread starter genesis1975
genesis1975
Unfortunately I have short memory; I have to make a drawing without cartilage, but when I launch the command creates drawing, I propose only the drawing hairs that I made with the cartiglio...how do you do to remove the cartilage only for this design that I have to do?
Then I have drawing models with cartiglio and only proposes those....and opens them immediately to make the drawing, with cartiglio
so you have a template (drwdot) for a4, a3 and so saying that if you have to change the score you have to remake everything from head instead of having a unique template (drwdot) and various sheet formats (slddrt).if I put some image it would be easier to help you.
then you can only delete the sheet you find in the feature manager
I told you how to do... .
enter the sheet property...which you find at the bottom of dx clikki and open sheet property1.webpAnd then just take it off2.webp
then when I entered the model with cartiglio I go into the property of the sheet and remove the check from "show sheet size"
exact, so you find a sheet that does not show any caritiglio. However inside that window you can change what you want, like sheet size and change ect. ect format.
Yeah.. just try. alternative and delete the sheet, but sometimes if in the caetiglio you have pictures these remain present.
I recommend you have only one template and more sheet formats
you unfortunately the pictures remain and you have to manually delete them by entering edit format.
if you create sheet formats to insert in a single drwdot template this problem does not show up and you can switch from an a4 to an a3 without problems remaking the design as, I bet, you have to do now
