detail levels, how do you use them?
  • Thread starter Thread starter windreef
windreef
I read the guide about it, but when I pass from one level to another, it continually gives me errors on constraints that were good to him, this morning he began to close me inventor at every step from one level to another.
I try to explain how I'm using them because I think something's wrong.
I have a set of a machine formed in turn by various groups (subassiemi) within which there are other subassiemi. Since some of these groups are customizable according to the "optional" of the machine, I made the copy of the interested groups and I made the necessary changes (averagely 5/10% of the pieces, so many pieces remain the same from one copy to another).
However, at this point it happens that every time I step from one level to another it gives me errors on some constraints that were good before (in my opinion, for example, because the marked constraints are good).
I have a doubt: but when we suppress the sub-assistances that do not concern me, why the constraints of that aid, in the main aid, are not suppressed?
I don't know if I explained well, if you want to ask.
But those hotfixes are all being installed? :eek:
Is there any files that enclose them together?
at the moment I installed the sp2 (inventor 2010), I must pass to the sp3 as soon as I have a minute. :biggrin:
Thank you very much
but the first download link, because the second is for who has subscriptions, or am I wrong?
installed sp3 and the hotfix indicated, but unfortunately the problem persists.
I think I'm wrong to use the levels of detail in the sense that I have very similar sub-axioms, so there are same parts that are part of more sub-syemics managed with the levels of detail. I believe that the constraints I put into conflict because they are related to the same part even if in different sub-assistances.
I don't know if I explained well. :confused:
after long tests I came to the conclusion that the levels of detail cannot be used as I want. I keep giving mistakes on constraints that go well when I move from one level to another (but not every time, that's the beauty). Then I'll put on a commitment, get them all back. then maybe I have to go to another level and bamm! jump again:36_1_4:
This morning I contacted the assistance :angry:, they have to call me back, I hope in the afternoon, then I will let you know how it ended.
I believe that the simplest solution (but not faster) is to do the old way, a set for each machine variant .:frown:
