detailed view of isometrics
leggera
Hello.
I would like to know if there is a possibility to make a detailed view of an isometric by dissecting only the part and not acting on the distance.
Do you want to do a detail or a section?
a normal section or a compost?
What does that mean?
I'm used to an inventor.
practically with inventor do a sketch, then you can select the part in a set that you want to dissect to see inside.
in sw I find only the distance, but it does not make me select a part or more parts. .
but do you want to do a decomposed section?
the idea is quite clear, but if you put an image made with inventor of what you want to get we all have the clearest ideas
therefore it is a decomposed section. calling her immediately with her name would help her understand the goal.
in the image I see dissected everything not only an object. and how did you tell him he has to dissect to that point and not 1milimeter more or less?
with solidworks the section besides with a distance, which is measured by the encumbrance of the outer object, gives it a reference like a board, a board (as well written in the guide http://help.solidworks.com/2018/italian/solidworks/sldworks/hidd_dve_breakout_section_prop.htm)
instead to do it on a particular only there are several roads:
-create a display status in the axieme where you only see that part (very simple with only one part because just select it, make island and save the display status)
-select the view in the design feature manager, expand it and hide all parts that do not interest
-select the individual parts visible in the view in the graphics area and hide them or open the sight properties, go to the appropriate tab and select the parts (this is the only way if the object to hide is not a part but a body of a multibody art)
