developed and folded sheet table at the same time
  • Thread starter Thread starter asblo
asblo
Hello everyone
I have a problem.
I have created a sheet and its function "fold", so, the development and bending of the same, happens suspending and reactivating the function.
in the table I must represent both the developed sheet (to quote holes etc.) and bent. How do I do that? if I suspect or reactive the function "piega" autometically even at the table will follow the status of the part.
can you "fix" a view on the table and make it independent on the side?
Just put in the table between the other views, "flated view".
I didn't see your specific case, though I saw you posted it.
Hello everyone
I have a problem.
as reb_bl said, just put the "flat repetition" on the table.
But you have to check if in the piece reactivating "flat repetition" this stretches. your piece has the "flattened" funz inside "flat recetition" suspended and so this does not stretch.
reactivate it and check that by activating "flat repetition" stretches and you're fine.
Now I have seen that flat repetition is in the list of available views. . Thank you guys!
hello to all boys; for a delivery I have between the various tasks to realize the putting into the table of a sheet quite simple. I would like to know, where can I find special rules regarding the table of a sheet?? what different rules are there compared to a simple table?
thanks to all
the sheet has no specific norm. must, however, be managed as from the request of the customer or supplier. not all also require development, those who require it could only want the encumbrance for the purchase of the material because the geometry derives it from the dxf or could require complete quadrature. You have to question duty. regardless if you do the development are mandatory lines, angles and bending direction
Thank you very much! ! !
