development element in centina
  • Thread starter Thread starter Camaleao
Camaleao
small technical exchange. .
I have this detail that I have to develop in plan... As you can see, it's in centenary, so the sheet must undergo a forced deformation, if I open the surfaces normally the tips... How would you proceed?
Then I tell you how I did... In the meantime, I take a simulation tour to see if I took it!:bekle:
Hello chameleon
in what form of catia?? you used the ho sheet.. What deformation factor k?? What are the tolerances? ?
if you place the model if you can and do not have copyright issues??? we see how to help you;)
Hello
I attach the model... then the tolerances I have on the holes that are about 0.5 radial, for the rest nothing in particular, in the file I inserted a preliminary deformation passage necessary according to me to develop the element..catia v5 r19 module shape
thanks rs4.. a question... did you develop the element taking into account the centin? Let's say that element in the tree that is called an element without a centin, I created it, because in my opinion that geometric construction is necessary to develop the piece (you notice if you try to develop the centinated piece), but the original element is that solid centinate. . That is why I asked for an exchange of views.
camaleao I used as base surface the surface.89 in geometric group element without centin. .
But that's what you expected, all right? Does it satisfy you? Let me know and maybe post that emptied from you
In fact, I wanted to know that passages would have used you colleagues in this bitter profession to develop solid "1" ;-)
the steps are different:
I have in shape design selections the surface develops in floor
more appropriate would be sheet metal convert the sheet metal model with thicknesses and parameters etc and then always develop in sheet metal module
