development loudspeaker conduct
  • Thread starter Thread starter Hilip
Hilip
Good evening to all
thanking for the excellent service of this forum, I would like to ask a question:
are at the very first weapons with inventor, the work I have to do is to spy on the ears of a forced conduct, to be sent to the company that will realize through the laser cutting of the sheet, all the ears that make up this diffuser.
the file that was sent to me (igs) represents all the diffuser divided into 40 cloves
until now I have proceeded like this:
I opened a new file for the development of sheets, importing .igs
what I get is the representation in surfaces (orange) of the whole set
Now what do I have to do to get a dwg or dxf for every piece of shit?
I'm only allowed to do it on a snitch.
the command "explains" doesn't always make me do it.
I'm wrong, you can help me. Thank you.
even if you are in sheet mode you can access the modeling board, thicken a surface with the "thickness" value, checking its thickening direction, then you can open the sheet and generate the dxf.
Thank you for the answer!
thickening and explaining a surface I can do it, what I can't do is do it on all, it only makes me do it on one, as if it could explain only one per file.
My conduct has 150 cloves to spy on, do I have to make a file for every surface that converts into sheet metal?or inventor can work and explain more sheets in one file?
if they are 150 single pieces you have to cut and then weld together you have to do 150 rows of sheet, generate the flat model, create the dxf of 150 pieces to cut.
then to see the result in a welded set insert and bind your 150 pieces.
I expected inventor to disappear into single files all my set, then convert them individually into sheet metal.
It means I'll create a *.igs file for every snitch and then it'll matter to inventor. Thank you.
try to thicken all in the same file, making new solid for everyone. Then you can try to create the parts in a blow.
