development mirrored sheet
  • Thread starter Thread starter DFMecc
DFMecc
Good morning to all, I have the following problem: a customer has passed me multibody files in sheet metal and its symmetrics obtained through part mirror. I need to put the individual bodies into the table and develop them. I don't know how to do for the bodies made from mirror part, as I don't get the flat repetition function. I had thought of using "sheet converts", but I should do it on multiple bodies: is it a viable solution? Is there a faster route by chance?
Thank you all for the answers! !
a sheet flat with the bending lines is identical, whether right or left. just spill the sheet. what changes will be the fold on 90° which becomes 90° down.
hello mechanicalmg, thanks for the answer. your observation is correct (obviously), but I should put a view on the table connected to another file to get the development.... was something I wanted to avoid, even because if then I need to make changes only on that piece, then on the development I would not find them... .
In general I avoid using part copies, but the customer has passed the files made so and I was looking for a way that would allow me to get the development quickly without having to remodel the piece.
I also do not like to use two parts but unfortunately solidworks does not provide different roads and obliges paciughi. otherwise you need to put the configurations with the suspended or active features and use that configuration to make the mirror. I usually do not break two physical parts but two configurations with the same code and I have in the attribute description "symmetric".
the mirror if made with the correct spun allows to separate father and son keeping all the features tree including flattening. . I don't understand where you're stuck.
I use thousands of mirrors and I have no problems in the table
You should also attach an image with the correct spuns to show what you're talking about.
Sorry I wasn't in the office.
However going ahead with the darts you look for, in the last menu just enter the check where I indicated to transfer all the features in the new part.
ps. in previous pages you can rename and choose the method of mirroring
