development of a sheet divided into two parts
ele5
hello to everyone, is it possible to make the development of one part of a sheet? i.e. I have a carter that I had to divide into two parts for external processing issues, how do I tell inventor what part I want to see in development?
thanks for the help
Try to explain yourself better, put some pictures of what you're doing that I didn't understand you.
sheet metal parts cannot be multibody (at least until ver 2015), so the problem does not arise! !
even if you split it into two parts with a cutting or extrusion type command, inventor still recognizes the part as the only solid.
should just click on any side of the part you want to develop and then launch the "flat model".
Careful, if you want the development of the other, you must first delete the flat model and then do as said.
inventor 2016!!:finger: has the multibody sheet, you derive the bodies and then develop them!
