luca.rgn
Good morning.
I'm trying to figure out how diesel expressions work in autocad and I'm doing some tests.
the main problem is with substr.
esempio: file name: xxxxxx-xxxx-xxxx-xxxxxx name layout: Developedthe goal is to replace the characters of the file name from number 18 to 21 with the layout name so I wrote this$(substr,$(getvar,"dwgname"),1,17)$(getvar,"ctab")$(substr,$(getvar,"dwgname"),.this expression is working and fine, but since I want to take only characters from 18 to 21 of the file name does not work.
writing this:$(substr, $(getvar "dwgname"),18,21)It takes all the characters from18th onwards.
Can you explain why?
