different areas for different phases of project
  • Thread starter Thread starter severinoartemio
severinoartemio
Good morning, everyone. I would like to have tried to look in the previous discussions, but without finding what it does to my case. I also believe that I am "losing in a glass of water" because my problem is definitely banal, but so much. I thank in advance who will answer me.
I have a plant of a small house to expand.
I created two phases "current" and "project" (with enlargement)
I want to know the two areas of the two stages, for the calculation of the surfaces. surface before and after in short.
what I would like, is to define two distinct areas, one that is confined to the external face of the walls of the "current" phase and one to "project"
In short, one that indicates 117 sq m, and the other 141 sq m, to understand, that are more or less the values in play.
And then I'd like to put them in an abacus to bring them back to the table.
But I can't.
what I do is define a scheme of new areas ( slp areas), but then at the time of the definition of areas. with the command area plan, I miss some of the views, including what I need, and I can select only the "current" phases and not the "project". I looked for some kind of switch to be able to select views of different stages, but I didn't find it.
I also can't edit the areas, as if it were the perimeter of a loft. should I deduce that there is no area object to be associated with a loft object? Do you need to take the measure of the floors? and in this case, how to eliminate the lines where the various floors combine, without joining them and thus losing the information of the distinct surfaces between "current" and added loft?
I hope I explained.
