different curves between a view and the other
  • Thread starter Thread starter brasiliano
brasiliano
I need not see some curves in a view but I have to see them in the others, here I am not able to do this job.
I tried through the layers, but disappeared in all views.
thanks in advance to all!! !
Bye.
I didn't forget about you.
the layers are used.
in "part" mode (or in combination) create layers corresponding to the curves (e.g. layer 5__curva1; 5__curva2; etc.)
- at each layer, make the curve that interests you.
in drawing:
- go to the layer menu;
- you can activate the general layer display (top model) or for each single view.
- choose the view you need (icon with arrow present at the top left in the menu' layer).
at this point, selected the view, reset the general settings (upper model) and the view acquired own and independent properties (forever? maybe yes).
- turn off the levels you want to turn off (e.g. layer 5__curva1; 5_curva2; etc.) ......
- n.b. saves the operation (at the top with the mouse in the layer area), right button "Save state" very important.
the game is made.........
