different materiale
  • Thread starter Thread starter sofa80
a situation type is a structure of various embluded plate, it is much more comfortable and slender to design it all from the environment of part that not from the axieme. then in table environment however each plate will have its design with holes machining etc.
this is a situation where a separate cut and not material is used
are techniques that mostly depend on what you are asking for production. In my case, often, I have to distinguish the "simple" profiles, that is, only cut to the saw, from the more elaborate parts that require a table. for the "processed" parts there must be a unique code, to be used in various subaxis, and I must be able to have any steps or dxf. This request is very simple when the code to be treated is a part and not a welded body to be extracted and to be managed in all welds where it must be equal. always in the same together, I can have many simple profiles. I can model them as a traditional combination, taking a lot more time, or I can make them a welded to be faster and have "gratis" the automatic cutting distinction.
at the end I make the profiles "simple" with the welded that is to be dissolved in separate and add the details " processed" as parts.
This remains always and in any case monolevel, when the situation is more tangled using traditional assemblies and I put the time it takes.
