different pannelli
  • Thread starter Thread starter philips93
philips93
good evening, I am new in the forum, I take care of carpentry and I am learning to use solidworks.
use mainly for furniture design.
once designed for example a wall cabinet would be convenient for me to obtain a distinct with the size of the individual panels.
when I go to create the design of the part I can't break the wall in single panels to be able to quote individually, also I would like to understand how to insert a table with the size of the individual panels-
Can anyone help me? I'm sorry if maybe the questions can be too trivial but they're at first with the software.
for the table:
design environment: insert>cutting.
part environment: to create the cutting distinction you have to activate the welding environment (even if you make wood or plastic) insert>saldature>salda
the cutting distinction appears at the top in the feature manager; expanding it there are folders inside which there are all the bodies of the model; each folder includes identical bodies (even a difference of 1 cent of millimeter on two similar bodies means two different bodies and two different folders).
with the right button on these folders you enter the properties to be filled out and recall in the drawing environment.
a shortcut for size is to right-click on separate cut and select selection pane; automatically the folders will be populated by the properties of the 3 sizes.
quotation of individual bodies in the same design file:
when entering the view select bodies in the property manager; it is reported in the file part where select the body to be listed, selected the or the bodies giving confirmation with the green check you return to the design environment and the property manager of the visual insertion.
of course it is subtent that the part model is made in multibody mode
instead of going randomly I suggest you do the internal tutorials of the program well done that give an infarination of the logic of the program and the controls and basic processes
