difficulty transformation formats and dxf
  • Thread starter Thread starter strange
strange
Come back. . .
I have a problem with files to develop. . .
I started from a step made by fusion 360, turned into asm, then for single piece par I created a body sheet metal and from that rebuilt the pieces (tanti)....
The problem is that now I can't save the dxf, it tells me that it's impossible to save, saves me a dxf actually empty. . .
I attach a piece of the many done so....the problem is that I also have urgency to make developments:frown:
Do you explain how to solve the problem?? . Tell me I don't have to remake all the pieces...
View attachment Zoccolo inf. postr._0.rar
Come back. . .
the only thing you have to do is use the "thin sheet" command from the tools menu.
eliminates all the rest except the imported "body feature"
Hi.View attachment Zoccolo inf. postr._0.rar
nothing to do.... always dxf empty....
With the fusion files, I don't develop them like that....it must always redesign them....but in this case I can't develop. .
your file still doesn't open it to me... different version.. .
[video=youtube;JuayyPEuI8A]https://www.youtube.com/watch?v=juayypeui8a[/video]
nothing to say....
It is that I always have a mistake in saving the dxf... tells me that it is impossible to save it... and saves it empty... even if I copy the par file from another side and I renounce it. . .
I can only import it into solid works, transform it into step and solid make development (or directly from sw)....
Why does it make me mistake if I do it directly from myself?? ? ? . . .
I usually proceed like this:
I open the step file, save it in asm...
I open the single parts, turn them into sheetmetal with the command "thin sheet" and then I develop....
with fusion 360 files, I have to rebuild the part with folds etc, because their program does not support the folds, percui is a nice mess and if obviously not, and turns them into automatic... for what I had done the features...
How do you do that? ? . . .
depends on who sends the files to me, in 2017 not having the folds in the 3d models is a problem not recently as you have no idea what you are accomplishing (for example a trivial washer goes to finish on the bending curvature and remains stunned, or an ink of sheeting goes into interference for the stamp of the fold).
said this almost never happened to receive rows of sheets without the folds.
in any case you can use the "convert part in sheetmetal" command where you will select the flat faces that interest you and solid edge will worry to insert the folds
done....but at the time of saving the dxf from always the same error: impossible to save... and the final file is always empty. .
I saw that but turning it into step and then working it, it does.
seems like there are links to something that prevents me from saving the dxf, which obviously (and fortunately) go lost with the step...
Can it be? ?
Can it be? ?
installed the last mp of the st7?
