Archimede Pitagorico
Good morning to all... in time "lost" I wanted to evaluate the idea of changing a digging/ picking potatoes used to "better" it according to my needs. at iron level welds and mechanics I arrange discreetly. . at the level of oleodynamics are almost zero. I'll explain.
the draft you see is to be interpreted as:
- black, chain tractor= existing
- red, convoy ramp = homemade
- blue, 2nd conveyor chain = recoverable
- orange and purple, case and product case support = not relevant
with a tractor from 25-30 cv to cardan I wanted to eliminate the bike with the chain, mount a hydraulic pump (if with multiplier or not you will tell) and mount a hydraulic motor (suitable) on the first chain + a second hydraulic motor in the second chain. 1 flow regulator in the second motor to adjust the chain speed (very slower... manual screening with operator). a 3-position distributor (pos. 0-1 fixed. Pos. 2 spring return) to be able to reverse the direction of the main tape only in case of jamming with a simple gas station (with return to zero spring).
that pump, multiplier, reservoir, engines, distributor, flow regulators can serve I ask who knows more about me.. but all this according to you is feasible? and at what prices?. leaving the possibility of wandering between workshops and recoveries of course
ps for the most curious, I would remove the 3rd point on the tractor and turn it into "semi-ported tool" given the structure "corposa" for a 30cv.
Hello and thank you.ps if the subject did not appear properly the moderators can move it to the appropriate section.
with a tractor from 25-30 cv to cardan I wanted to eliminate the bike with the chain, mount a hydraulic pump (if with multiplier or not you will tell) and mount a hydraulic motor (suitable) on the first chain + a second hydraulic motor in the second chain. 1 flow regulator in the second motor to adjust the chain speed (very slower... manual screening with operator). a 3-position distributor (pos. 0-1 fixed. Pos. 2 spring return) to be able to reverse the direction of the main tape only in case of jamming with a simple gas station (with return to zero spring).that pump, multiplier, reservoir, engines, distributor, flow regulators can serve I ask who knows more about me.. but all this according to you is feasible? and at what prices?. leaving the possibility of wandering between workshops and recoveries of course
