dim expert
  • Thread starter Thread starter PiegatoreSolidworks
PiegatoreSolidworks
the problem that I put you today is this: is it possible to add on the already existing cartiglio a dim expert quota made on the side file without having to remake all the cartiglio?
from how much I could experience, once I added the new share in the part, go to the table (cartiglio), in the drop-down menu "view" choose "show/hide annotations", click on the new quota that you will find in grey and then close the command going back to view, show/hide annotations; at this point the new quota is visible.
If you don't find it, return to the part, right button on the new quota, choose "change view of the annotation".
I hope I understand your request and have been helpful.:smile:
Greetings, Mauro.
p.s. I have the 2011 version of solidworks.
Greetings, Mauro.
Thank you, mauro, I'm feeling right now.
p.s. go immediately to present you in the appropriate section,otherwise here you "arrabbiano". :finger:
Okay, thank you, I've been writing for a while and I felt like I've already introduced myself, but if that's not "I'm going to go right away." :smile:
will be the age....
... click on the new quota that you will find in gray and then close the command going back to view, show/hide annotations; at this point the new quota is visible.
sincerely it doesn't work... I solved by putting the same tolerance directly by hand on the cartilage!
Sure, manually on the cartiglio you can do.
but did you need to add the quota or tolerance?
I tried the quota, but it can be interesting to try to edit even only tolerance.
We could help you, but honestly, I'm not sure I understood everything 100%.
in sw you can manually quote or import the model quotas into each destination.
to make it simple: I created a model and then the cartouche. in a second moment I added on the side file a dimexpert with so much tolerance clearly. Now how do I take it to the cartella without having to do it again?
p.s. I only do to learn, if I have to remake the cartilage there is no problem!
put that quota in the properties of the side file.
when you add a voice/note in the cartilage go to call it back with the button connection to the property in the property manager text format section note.
Hello
marco
