max81
I would like to learn how to dimension an orbital motor, and looking on the manual of oleodynamics of speich and peels is reported a diagram of the isorendiments, but it is not explained much on their use, therefore I ask lumi to someone.
from the comer catalog, I extracted this diagram of the motor glt315 (prese by case) with 326,3 cm3/turn of displacement:
correct me if I'm wrong, assuming I want a pair of 400 nm and 150 rpm, from the embroidery diagram that needs a pressure diff of about dp=90 bar and a flow rate q=50 l/min, also my work point in the diagram is found in the ellipse with yield 88%.
how do I use this performance, in particular is volumetric or hydrochloric performance?
hypothesized that it's the dromechanic performance I would have: mt = (dp * vg * uhm) / 62,8 where dp = pressure diff. (90 bar), vg = displaced (326,3 cm3/giro), uhm hydrochloric yield (0,88) and mt the torque provided by the engine, then replacing we get a minimum torque mt = 411.5 nm.
Is my speech correct?
