isd88
hello to all, our project progresses great, thanks to you I found the right material for our wheel and casting brackets, but now we have come across a blind alley: directional solidification
Here's the problem: Our geometry is such that between 2 parts with a relatively low thermal module there is one with a very high thermal module. the three zones I will call them b c.
the area to present a thermal module of 9,6
zone b 11,2
the area c 8,4
(millimeter values)
Unfortunately zone 2 is inaccessible so the materozzes should insert them in a or c. we divided the task and to me is touched the solution "in some way insulated to"
I have done all my calculations and found that theoretically if I can artificially increase the thermal module by 30% the problem is solved.
that you know there is a way to insulate a part of the jet into the foundry on earth?
zone b 11,2
the area c 8,4
(millimeter values)
