directives on light exhibitors
  • Thread starter Thread starter drafter
drafter
hello to all
They asked me to design a backlit advertising board. would you tell me where to find a list of the technical/normative requirements necessary for the marketing of such products? Thank you.
Maybe:
Low voltage and electromagnetic compatibility and harmonized standards
Consumer code
technical standards for lighting
the device must be
ip 67
- total protection for penetration of solid bodies and powders.
- protection against immersion in momentary water for 30 minutes at 1 meter deep.
have an electric power switch
in the sense that when you open the board
no more electricity
see the rules for public lighting
Thank you very much
shiren, but if you go inside, you need ip 67?
My curiosity!
Hello ing...
It's a pleasure to read
who builds and markets such products
does not know before having to be exposed
needs an imq certification and similar things
could also be an ip 44
but you know better than me than with current metal profiles and existing seals
changes little
Anyway
bulletin board (type: service advertising plant).
is considered the product
two-dimensional, made of openable or without glass,
supported by
suitable support structure,
installed on wall or on special support,
aimed at spreading messages and information of public interest,
exercised by public bodies, associations, political parties, trade unions,
theatrical and cinematographic representations, even outside the home.
can be used on the wall, in the proper seat of public exercises
Food and beverages and hotels for price exposure
related to product or performance lists
the advertising form of this type, is allowed in the dimensional limits of 120 cm. x
80 cm., or 40 cm. x 120 cm.
structure and composition materials, must
have light frames, made with profiles other than anodized yellow color or
aluminium.
any emblem or symbol of representation of the agency, of the association
or of the different subject among those referred to in Article 4 of this Regulation, may be
applied on the outer and upper part of the frame, with maximum dimensions of cm 20 x
20.
the boards, if placed in operation in adherence to border walls with the road
public and with sidewalks, must have a maximum protrusion of 10 cm from the wire
vertical of the masonry and the minimum height from the ground can not be less than 1,00 meters.
if installed in other places among the possible ones provided by the regulations for the plants
advertising, the installation will be subject to the distances provided by the general legislation.
the ground height with the closest part to the ground of the installation, cannot be
less than 1.50 mt.
