director with automatic content from block attributes
  • Thread starter Thread starter Raffa1736
Raffa1736
Good evening to all,
I have done a research in the discussions, and it seems to me that the subject I will ask below has not been dealt with. If that were not so, I apologize.
I would like to realize the following automatism:
- I have several blocks, which contain, for example, all three attributes (product code, surface finish, supplier);
- I put on the table on several layouts a composition of these blocks (my table);
- in the layout, I would like to make sure that the annotation directors, when applied to a block, automatically "absorb" the attributes data, so that the annotation becomes automatic.
being the blocks always the same, it is an absurd job to insert all the times the descriptions (even copying and pasting becomes heavy).
Thanks in advance to those who wanted to help me.
select the block and give the point where to place the texts.
Thank you so much, it does exactly what I wanted.
But I wanted it to be done in the paper space, since it is where the annotations are placed.
Anyway, he does exactly what I was asking.
Thank you very much
Sorry, I wasn't worried about the layout.
besides the att2leader command I added att2leaderr that is equal but adds the pane to the text.
spectacular, thank you.
now only works in the layout, and also puts the pane. If you don't want the box?
I might need it or not, it depends.
Thank you so much anyway!
If you don't want the box, use att2leader.
if you want to delete the pane of those already inserted, select them and set them, in the property window, textgap with a positive value.
Thank you
very kind
