directory per fix_params.log e std.out
  • Thread starter Thread starter lollone
lollone
Hi. .
I wanted to know if there is an option to set in the config to set that the creation of fix_params.log and std.out files (which in my case happens at every drw creation, see http://www.cad3d.it/forum1/showthread.php?t=12186 )
happens in a given directory instead of on the work directory.
files overlap at every creation but I would like to avoid having files everywhere.
I reply that it is possible, so do not disperse, because to me you create only a file: std.out and always in the same folder.
What I can tell you is that:
  1. the icon on the desktop with which I launch proe to the point "from" there is f:\client
  2. the config.pro file is in the folder f:\client
  3. the std.out file is created in the folder f:\client
while I'm
  • the icon on the desktop with which I launch proe to the point "from" there is f:\cliente\trail
  • the config.pro file is in the folder f:\cliente\trail
  • the std.out file is created in the folder f:\cliente\trail
So you draw the appropriate conclusions, regarding the other file you create I do not see it.
