disable the parametric design features in a.cad arch. 2010
  • Thread starter Thread starter warburg
warburg
Hi, I was trying the trial of a.cad arch. 2010 and I wanted to remove all the parametric functions, to have only classic autocad. It happens that when I go to "profiles" and select autocad, the current profile, I do ok and go ahead, at the next start the program recharges as architecture.
I guess it's a banality, but I didn't find any more suggestions. do you know how I can make the classic profile permanent?
C
from the 2006 version are introduced the working areas, customized your interface type wssave and nomination, at the next start of the software will already be set. if necessary to recall the work area type workspace.
Hi, I had done so but it didn't work on reboot. However then I solved by understanding that during the installation process you can specify that you only want acad.
