disabled request save files with autocad lt 2011
  • Thread starter Thread starter ERMESMARONESE
ERMESMARONESE
Good morning to all,
I'm new in the forum, I used the search function but I couldn't find anything. . .
the problem I have ' this:
I open designs several times a day most times just to print them, every time the program requires me to save.
Is there a possibility to disable this request?
ermes
I don't think there are any variables that inhibit the rescue request.
if someone can deny me.. .
noAnd that's right!
Why should it exist? It's like I made a doorless elevator because people don't have a passion to wait for them to open up. It's a security mechanism that shouldn't be disabled!
in autocad 98 lt if I open a design and then the mold without touching anything else does not require rescue. . .
However try to open 50/60 drawings and then at each closure having to click on save, it is a waste of time.. .
you could connect a command reactor to the _plot command that let me out without saving, but since you have autocad lt, fall the stage...
And what will it be? Launch the print, close the file (saving or not), open the next dwg and the first print still has to go out. I find this ridiculous request!
I believe that this request for ermes comes from 2 factors:
1) ermes opens the dwg gives it a "look" for consultation, then zoom, pan, turn on/off layers etc. and then wants to exit.
from its point of view the design has not been modified, he didn't delete or add anything, so why autocad should ask me if I want to save him?
If I save it like this, I will have at least a different zoom, as well as the date obviously.
2) print ermes, and also in this case (from its point of view) not changed Nothing.
So why does the pc ask me to save it?
It's true that in this second case even if I tell him yes, the dwg remains as it was before.
but ..... it changes precisely, the date.
Maybe this is important to him.
I never used the lt98 version, but the lt2000, and then .... but the behaviour of ermes seems to me to remember it, I don't want to say some drafts.
with the old versions of autocad (10/10.3/11/12/14) I could with the close command to close all the open dwg and choose between: save me all/do not save me anyone.
if I remember well.
But as I have not yet understood which version ermes you use, i.e. if lt or full, I don't know if your problem can be solved with a lisp.
problem that is not so strange, since it is present on the forum autodeskhttp://forums.autodesk.com/t5/visua.../disabling-quot-save-quot-command/td-p/900352http://forums.autodesk.com/t5/cad-managers/disabling-commands/td-p/1192248
...I open designs several times a day most times just to print them, every time the program requires me to save.
create this script and assign it to a button:
_
No
You have to leave a space after n and place yourself on the next row before saving.
... the time that "by mistake" will move some line without noticing it will return on its steps:biggrin:
that then bsta give indigo, the save is default active button.
but he must print 50-60 drawings!! No, no, no, no. :4410:
want to work jump on me!...
:36_1_10:
_
No
I'm not an expert... I can't assign a button to a certain script, at most I can assign a button to run scripts, how do you do it?
every time I open a drawing I move lines by mistake! thinks I once drew a table and the next day became a sofa... What a story!
