display a cylinder axis
  • Thread starter Thread starter iron72
iron72
Hello.
and from a while I don't use cat v5 and I would like to be able to display a cylinder axis and select it in model mode (so not in the sketch)?
because I would like to give a reference board for a matrix that would be a pocket with a hole.
if you need the real entity, you need to create a line (pt-pt from center to center of circumferences)
if you only need the reference, simply select the circular hole face.
if you were looking for the forum you had already talked about it and I had docuemnta a 3rd chance!! :-)
the solutions placed are very correct. I add that if you have the generative shape design package, just click axis on the object and in the geometric group you create it.
