display and print different writings from the font
  • Thread starter Thread starter rubrie
rubrie
Hello everyone,
as I anticipated in the title I have this problem: I use autocad 2007 lt and when I open the graphic boards elaborated by me or by my colleague I display the writings incorrectly, i.e., known in the properties that the space between a letter and the other is greater than the parameters I fixed or my colleague previously to that chosen font.
e.g. my correct phrase with the right parameters is: northern prospectus, while, after a while working on the file, the sentence suddenly becomes me, p r o s p e t o n o r d.
Help me, thank you very much!
Maybe you and your colleagues use different fonts. try to see if the problem also occurs when using a common font such as green or aril
No, we use the same font.
the only different thing is the software, or rather, the software version, I use autocad 2007 lt while others use autocad 2012.
Could that be the problem?
check that the text in distributed mode was not set in 2012.
I don't remember it was in the 2007 version. It's possible that then your version is acting weird.
you can also attach the file that gives you this problem, with the only text.
but this option "distributed mode" where I find it? Besides, by default is it active? However I attached the file.
thanks for the help you are giving me
find it in the text editor.
However you have not attached anything.
