display "double" annotation quota
  • Thread starter Thread starter KarlHeinz
KarlHeinz
Good morning to all,
I have a general set where I mounted a sub-assieme in quantity 2.
inside this sub-assieme I created a annotation quotation in which I also added a description for a verification to be done to the assembly.
when I create the table and use the exhibition/cancella of quotas I only see a quotation, but in reality I need to see 2 for the above reasons
Does anyone know how I can do that?
ps. I am forced to use the annotation quota within the model because there is a whole procedure behind that I am not explaining, so I cannot create it differently.
insert the same annotation twice. I always do it when for example I have to display a note of a particular on two different views.
aminati
I can't insert the same annotation twice, because I have an automatism that makes me count these annotations and in a dedicated area of the cartiglio I have a parameter that indicates the total number.
In this way I would be 4 notes instead of 2.
thanks arni1,
The trick works..the problem is that I should define the flexible axieme..and whenever the warning asks me whether to insert it as flexible or not.
to users this will certainly not please.
thank you very much anyway for the suggestion. I will definitely be useful in other cases!
Hello! !
