display error in the table
  • Thread starter Thread starter AngeloB
modifying the 3d reference, on the table appeared of the semicirculations that are the threads gone completely out of scale. I can't remove them and export to dwg they keep being visible. The only way to eliminate them is to change the reference view, but I have to put all the quotas back on.
solidworks 2019
Angel
in the environment part or together check that the cosmetic threads are correct, especially if inserted by hand
in environment design pass view from quality draft to high quality
Hello, everyone.
Do you ever see this error in the table?
Yes, it is a nuisance, but it is easily solved. while you have the table open, open the model and make a force regen (ctrl+q), save the model and return to the table. They should disappear.
for rocks. threads are inserted in the 3d model, they are not forced.
for re_. I tried but it doesn't work
I have not written that they are forced, but that in case they are inserted by hand, that is not the automatic ones of the guided drill, you may have written badly the value (m16 instead of m6).
have you checked that they are displayed correctly in 3d?
have you passed from high quality draft quality or vice versa?
However, a pdf is used very little if not to make a mere statement.
use the file to make verifications, otherwise you only have 2 possibilities:
- You're lucky someone's got the same problem and remember if and how he solved it.
- you have to be able to recreate the same problem that not knowing what it is due could even never manifest itself.
You will understand that none of the two hypotheses are possible.
insert in the profile the version of solid so you do not find to download unopenable files and if you can search for news of any bugs
Strange, it's a problem we've been having for years and this way we've always solved. when you return to the table do not close the model, but change document with the model open in the background. try also to make a ctrl+q and a normal regeneration (semaphore) at the table. This is an annoying thing, especially when we export packages of a few hundred drawings with the pdm and we have to check that all exports have gone well.
Sometimes it happened to me. I usually delete the view that has these problems, then cancel the erasing operation with ctrl-z and the view reappears correct.
I'm not sure because I figured it out at the end of the job. but it seems to me that just pass from hidden lines visible to removal hidden lines and errors disappear. as soon as I get back I try and tell you
when there are bugs with cosmetics sometimes it is also useful, in part environment, to return to function and leaving giving the ok. even if you do not make changes sometimes you restore everything
can be a graphic card problem. make sure it is supported and updated.
if the problem persists with assistance
confirm, just switch from hidden lines visible to removal hidden lines and vice versa and error disappears
