display letter "m" thread
  • Thread starter Thread starter D4n13l
D4n13l
Hello everyone
I have a small problem, I created new thread tables starting from the iso.hol and renamed them with other names and hence no problem.
the problem arises when I go to quote in the table the threaded hole taking the holes created by me, if I use the standard iso thread when I go to quote with model annotations show me correctly that it is a thread with "m", while with the holes tables that I created me displays them as "ø".
Can you help me understand the problem where it is?
Thank you very much
other thing there is a method to ensure that when the holes are listed, the quantities for example n°3 holes ø6 are displayed.
Hi, I did a test... I edited with notepad the iso.hol file by creating other instances of diameters and steps and does not happen to me as you say; ie the m as prefix quota comes out automatically while the step obviously does not.
I usually solve it with the parametric notes.
also for the issue n° holes is worth the same speech. . .
example: you create a manual share in [Bleep] in the display tab @om&d [Bleep] x &pitch:fid_ [Bleep] <a capo=""> n°&p [Bleep holes equidistant.
instead of asterisks enter the id of quotas and parameters. then if you want to be more productive you fall all in a macro and go much faster.
p.s.
for convenience in the model tree I see by default the id column where I read instantly all ids of the features. is very useful in these cases.</a>
p.s.
Bye-bye.
thank you so much for the info you can by chance show me an example image to better understand what you explained to me?
p.s.
I tried from the iso.hol file and copy it with another name leaving everything unchanged but at the time when I create the holes with the new "iso" these are always displayed as ø and not m, while if you use the iso.hol in the holes displays the letter m
attention to the "cold" of the .hol file: when you create a new library of holes by copying from an existing one, in addition to changing the name, in the head of the file, there is the name of the drilling table, if you do not change the name, the program does not see it or sees it in place to the other with the same name!
I know that in fact I changed the name inside them and sees them, that's not the problem.
the problem is that I can't understand why threaded holes display them to me with ø instead of m in 3d and then logically in the table setting for the tables I copied from the iso.hol file
as you see in the first image with iso default of creo puts me m101582206670513.webpin the second image as you see with the hol file that I copied from the iso puts me ø101582206713843.webp
there must be something in the new table, because of .hole files I made in the past (always copying from an existing one) and I never had any trouble like this.
in the threaded hole you made with the new table where the ø10 comes out, check that in the parameters of the feature on metric tell you yes
