sagara_939
Good morning.
use solidworks 2018 on pc with certified video card. For a while, on some asses, he's been making me an annoying joke. while setting the shaded display with edges, some components are displayed without edges.
Here is a screenshot
as you can see, the two stems attached to the base plate do not have the visible edges. this generates confusion during design. the strange fact is that the other components have visible edges. I tried to open the detail without edge, but it is displayed correctly. being this particular also in other assemblies, opening one of these also is displayed correctly.
This is not the only exempt. I have a fairly complex set that has different details displayed this way. Sometimes, it's hard to work.
I have already tried to:
Can anyone help me? Have you ever happened?
Thank you!
as you can see, the two stems attached to the base plate do not have the visible edges. this generates confusion during design. the strange fact is that the other components have visible edges. I tried to open the detail without edge, but it is displayed correctly. being this particular also in other assemblies, opening one of these also is displayed correctly.This is not the only exempt. I have a fairly complex set that has different details displayed this way. Sometimes, it's hard to work.
- set all possible combinations of display in the options menu
- reset software default settings
- uninstall the software and reinstall it
Thank you!
