display text cat v5r21
  • Thread starter Thread starter Rosko76
Rosko76
Hello.
It is from this morning that I am trying to restore default properties in text properties.
In summary, I opened a table and I no longer see the values of quotas and texts inserted in the table.. .
to overcome this problem I must select all quotas and texts go on text properties and
select blank background(no). ...
I wanted to know if there is a way to set in properties tense the empty background (no) permanently.
You have to act on the standards but you only do it as a cat administrator.
search in the forum you should find the procedure.
Hello.
I'm meeting the same problem, I can't view all the texts in the table (quotes included).
setting on the properties of the blank background text(no), then everything works.
I entered admin mode, and tried to change the value in the variable in my .xml file, in the standard,style, text, text, blank background = no.
Nothing happens.
Can you tell me how you solved it?
