distinctive base kitchen hoods in sheet metal
  • Thread starter Thread starter dark2020
dark2020
Hello everyone,
I am new to this forum and I would have a question to ask you.
I'm a new mechanical designer, and I'm supposed to work in a company that makes kitchen hoods.
ask to make the distinct base in excel of the hood, but having never drawn kitchen hoods I don't know.
would someone have an example of distinct base sheeting for hoods or similar to be able to see or explain how to do it?
Thank you all in advance.
p.s design in solidworks
is the company that must tell you what it wants to have in the distinct; If you want a distinct executive and commercial, if you want the distinction of the individual plates....
based on this you decide how to develop work if as a whole, as a multibody, with structural elements....
If I had to make the distinction of individual sheets? I assume that a kitchen hood is made up of about four or five plates no longer wrong? how to make the distinct base in that case?
if you work in the environment together with each sheet consisting of a side file then make the distinct materials.
if you work in the environment part multibody and make the sheets with the appropriate functions then make the separate cut.
What is your solid knowledge?
my knowledge of solid enough to know how to make distinct material and distinct cut...only I wanted to understand since I tried to draw a hood and put in flat repetition on the design then making the distinct cut gives me only one element and add the.measures just?
my knowledge of solid enough to know how they make distinct material and distinct cut
knowing how to make a separate doesn't just mean knowing where the command is and how to put it in the drawing.
I don't understand in this sentence what the question is. Are you asking the forum if you have to put sheet metal measures? if you have to add the measurements in the cutting table?
you did a part with inside one body made in sheet mode, how many elements should you see excuse?
si for example sheet only flat repetition.how do.the distinct base? I ask to be explained how everything is done here.
Look, you're not explaining yourself at all.
What do you want to know?
a single sheet makes no sense because it is a unique element and the information will be contained in the paper mill and in the drawing quotas.
If you need something else you have to explain it well because you can't read in people's mind.
We hypothesize that you have to make the separate material to give to the purchase office, who makes nesting or anyone who needs the size of the sheet needed to produce that design.
make the model with the sheet module, then in the table insert a view, normal or flattened, and the separate cut, which you can use, which recalls the properties that interest you, which are usually; material, width, height and thickness.
I really can't understand what is the motivation that prevents you from explaining yourself well, maybe with pictures or examples, knowing that those who read don't know anything about what goes through your head.
note in margin:
this is not a problem of solidworks, but of management and perhaps industrial technology.
the inability to use a punctuation and a basic grammar make periods of a few dozen words difficult to understand
look that there is no need to polemize, nor to offend alluding to inability of any kind. I apologize if I didn't understand, anyway I solved. Thank you cmq for trying to help me.Good evening
if you have solved, report the solution for those who will have your own problems in the future.
