Distribution systems
  • Thread starter Thread starter frifer
frifer
Hello, everyone! :
My name is igor and I'm new here!
Would anyone know where I can find components for refrigeration systems?
in revit cé little and what there are unused models.
in particular I would need:
sabroe screw compressors
piston compressors gea
evaporators
I looked at all the sites I found and on the sites of the producers but there is nothing.. .
thanks in advance
igor
Hello and welcome.
I'm afraid you'll have to build them like this:
1) family of "general metric model";
2) generic model change to "mechanical equipment" or " ...special".
If you already own the model in another format you can always import it into the family in dwg, dxf, sat acis or others.
Hello! thank you for the info!
What do you mean by category change?
Is it a good idea to import objects from other formats? other perosnes on other forums told me that it is a dare that must be avoided absolutely because from a lot of problems... Besides if I amount an autocad file it matters to me as block and I can't change the material... and how do I have for example evaporators for which there are 30 different models? Do I have to have 30 families or can I somehow import them all into the same and choose the desired model?
other perosnes on other forums told me that it is something that must be avoided absolutely because from a lot of problems.. .
"absolutely" no, but that is at least one last beach. if you have usal alternatives.
Besides if I amount an autocad file it matters to me as a block and I cannot change the material. . .
This is not true
depends on the family and how it is generated/managed.
I imported a dwg file into the drawing but I can't change the material!
What can it depend on? the material applies it, if I close the project and reopen it I see the material listed as I put it, but in the view I see the color I used in autocad. and the rendering idem..
how is it managed/generated? How am I supposed to do that?
grzaie
