do not display all contours on selected object
  • Thread starter Thread starter Pippo & Tina
Pippo & Tina
Hello everyone,
I'm sorry, but I'm new to using rhino, something that messs me up a lot is that when you select a body, all the edges and lines are highlighted, preventing me from seeing the possible references I need.
do you know if you can remove or reduce such evidence?
thank you very much for the kind collaboration
Good day
Hello everyone,
Good day
the only method that comes to mind is to select, for viewing, the "technical" method. makes it easier to read the lines of the whole axieme, allowing you to see the selected part better. (click with the dx on the label, at the top left, of the display window and scroll the various options: wireframe, shaded, etc. the option is present in rhino5, it seems to me that on rhino4 there was not. ).
I hope the indication is useful.
Thursday
if for all lines you mean isoparametrics you can set in the options the display mode of the selected particular.
if you remove the display of the iso the selected piece/srf only change in color and you work much better.
I did some tests and, removing the iso and changing some other parameter like it seems to me the thickness or I don't remember well what, now goes 10000 times better
thanks to both for the help
greetings and good to make
