document property, "image quality", how does it work?
  • Thread starter Thread starter Atreiou
Atreiou
regularly work with large assemblies with thousands of parts, (which default weight load) formed mainly by the same repeated parts tens of times.
to improve performance and speed. I was advised by the assistance to adjust the parameter "image quality"
in the property of the document, which from what I understand should increase only the performance at the graphic level but not necessarily as opening and reconstruction, is that correct?
But now we need clarification, let's imagine that to a part imposed the parameters as indicated in the image, if this part is then contained in a set, should I apply the same "regulation" also to the assemblies?
or if the part has a higher setting, if the axieme that contains it instead has the set slider in less quality how does the regulation affect the performance? what is contained in the axieme passes everything in low quality?
the answer I need to understand if I have to re-pass the entire library and lower the quality of the parts I use most, or if it is enough to set the quality on the axieme that contains them.
in the properties of the joint document is specified if the quality must also be propagated to the parts
Are you talking about the second tip from the top that I posted is not activated?
No, not in my asses.
by what I understand by setting that would not be necessary to implement that regulation on the parts, correct?
If I have to make a decent rendering, is it always better to increase that setting if I kept it down?
the second slide, the lower one, on what does it work instead?
Besides in some axiemi grandicelli, the first slide is disabled, but not even in the guide I find why. .
http://help.solidworks.com/2018/italian/solidworks/sldworks/r_image_quality_graphic_triangles.htmhttp://help.solidworks.com/2018/ita...y.htm?id=87b566db98f94f5094f1cfdec864cdcf#pg0
just make a test: the minimum value is set in the axieme; in the model you find a circular element and notice that graphically appears as a polygon, now opens that part and you notice that even here a polygon is displayed while not having changed the settings.
And I have to make a decent rendering, is it always better to increase that setting if I kept it down?
What question, a rendering in which you see the circles as polygons is a decent rendering? you will find a compromise between quality and performance
guide:high quality rln/lnv resolution and lattice structure:
controls the image quality of the template edges in the designs.
you are in great axioms modehttps://www.cad3d.it/forum1/threads/risoluzione-ombreggiata-e-qualità-bozza.53189/
