does not display results
  • Thread starter Thread starter nicolapastena
nicolapastena
Hi guys I'm using ansys 14.5 (the problem that previously gave me about imporating iges files no longer) and a problem arises, analyzing any structure, I can't get out the results (diagrams of moments) vnmises etc. comes out all red. I leave you the code of a simple beam if someone knows how to help me
Preprocessor!
Keypoint, 1, x, y, z
Keypoint, 2, x, y, z
l,1,2 line from keypoint 1 to 2
et,1,pipe16! element type = pipe 16
keyopt,1.6,2! this is the changed option to give the extra force and momento
== sync, corrected by elderman == @elder_man
mp,ex,1,70000! material properties, young's modulus, material 1, 70000 mpa
mp,prxy,1,0.33! material properties, major poisson's ratio, material 1, 0.33
lesize,all,20! element sizes, all of the lines, 20 mm
Imesh!
finish! exit preprocessor
/solu! solution
antype,0! the type of analysis (static)
dk,1,0,0,all! apply to displacement to keypoint 1 to all dof
fk,2,fy,-100
The
finish
save
/posts
plnsol,u,sum,0
plesol,s,eqv
Could it be some 16 pipe keyopt that isn't active for output?
