dotted inside a cosmetic does not appear on the table
  • Thread starter Thread starter opua
opua
Hello everyone, I can't understand why on a table I can't make the sampling appear inside a cosmetic created on the model. to do the simple things I created a simple circumference, of course during the creation on the model I chose the sample parameter (as I always did), and punctually it is displayed on the model but, when I deceive the corresponding table the dash only appears if I go above it with the mouse pointer, then for an incomprehensible reason it disappears... basically it seems that below it is but it is not displayed.
Can you please help me?
Thank you
do this test:
edit the deduction and rent the spacing.
Sometimes it happens that, by default, the spacing is too wide, so wide that you do not see it.
otherwise it comes to mind that similar things happen when a section is created in correspondence to bad surfaces on the hook and then you have problems seeing the section
hi, thanks for the tip, I tried also how you told me but nothing to do the situation remains the same:frown: I also tried to create a new table by inserting the views of the usual model but nisba... .
do this test:
how do you edit the texture of a sample cosmetic created on a model?
once created, redefining the feature, I can only redefine the boundary geometry.
