double separate bubbles base
  • Thread starter Thread starter gp1nick
gp1nick
Realizing axiemi drw, I call the separate table base and then use the option "create all bubbles". If I have 2 or more times the same detail puts me one bubble and not 2 or more separate bubbles with the same number. Is there a parameter to activate in config?
run twice the command creates bubbles-all. the first time you're going to have one component for each row of the bom. the second time you will be swollen all the components for each row of the bom.
