doubt about cosmetic thread
gtsolid
I have a m50x1.5 to represent. the greater diameter is about 50.5mm and carry it back to the 3d sketch.
when I go to make the cosmetic thread, however, I know that, in "ansi metric" the available options come up to m48x3.
is it possible to create a new profile?
Yes, thank you.
I would also need m52x1.5. Here the din stops at m50x1.5 though. .
by choice:
- make the normal hole and then you put the note of cosmetic thread
- do the m50 then double click on the second function sketch and change the hole diameter and double click on the cosmetic thread and change the thread diameter
. create voice in the toolbox
how to create a new voice on the toolbox? I would also like to add a throat f.
toolbox = library, right?
how to fast a thread in the toolbox is switched on both the guide and the forum
What's that?
Okay, thank you. I'm gonna go find her.
the throat f is the discharge according to uni4386
the exhaust throat is not part of the toolbox that provides only holes and parts library.
you have to do a library function that doesn't seem to be included in the default ones present in solids.
Here are a couple of gorges http://solidworks.cad.de/libf_div01.htm; if they don't match you take one, save it and change it
I tried to add a feature, that is the f throat, present in the "part1" file inside the hole present in the other particular. I get error unfortunately.
probably the work that I have in the library covers a smaller diameter than the necessary one and does not find material to cut, going in error.
Is there a way to make it parametric?
library functions can be parameterized with configurations.
escaric gorges, such as keyholes, centring holes and other have measurements covering ranges. f1 gorge for trees up to 5, f2 gorge for trees from 5 to 20 (they are given randomly) and so on
open an extended library function (there are those loaded when installing solids like flash drives, seeger and see how they are managed.
in the configuration table you have to enter all the parameters that change that feature of lbreria
One more thing. in the attached file I would like to make a m72x1.5 in the side hole. in the known wizard that do not even appear the din machine threads, but only the "straight pipe upholstered thread", for the pipes.
being female the minimum diameter is 70.4mm, reported on the model
the word machine threads appears in the cosmetic thread.
wizard of what?
and what is the question?
try to be clearer in asking questions
generally on a normal hole where you insert a cosmetic thread din or iso you the quota as thread and puts the step?
