asblo
often in the workshop to finish a plate or a flat piece we use the grinding to lapidello, directly from the semi-finished piece, fast and not expensive operation that allows to give a “pelata” of flatness when there is no need to put it in fresa.
do you ever have this requirement in commissioning designs to third parties? I am always in doubt about how to indicate it to drawing, because in fact it is a rectification, so I should indicate a low roughness, but I would not want it to be interpreted as a plate first to fresare (with adequate overmetal) and then rectification, much more expensive and useless operation (if not needed).
how is the correct way to indicate a flat grinding from the crude?
