doubt undercut
  • Thread starter Thread starter conradsm
conradsm
I ask for information by piece to be realized in zama with a mold.
Is it possible for you to make the mould for this piece without big problems or are there problems of subsquadra that should be seen again?
It's 18 x 37 mm,
hole ø 14 x ø 16 outside
I have to deliver the design to make the mold to third parties.
thanks to anyone who can help me understand.
Corrado
by looking at the piece does not present any subsquadra.
you should add side view and view from above.
so it is easier to see subsquadri.
Hello gianluigi
Hello gianluigi
Excuse me, can I ask you a question?
from the geometric point of view how do I say whether or not there is a subframe?
if there are no angles at 90 degrees?
a lot of curiosity for molding
Good evening, everyone.
starting from the assumption that I have experience only in the world of plastic molding, but the posted piece has subsquadri.
the passing hole or the studs at the ends are subsquadri, depending on the piece born "in pedi " or "drawn"
davide
Could you understand better? Thank you.
[MENTION=26924]fly[/MENTION]zamak material
to produce it maybe you have to think of a shell with gravity fusion
or a die casting mould
It's a question
Thank you very much
It's a question
Thank you very much
I was referring to the subsquadro.
thank you very much for the respost cmq
It's a question
Thank you very much
[MENTION=26924]fly[/MENTION]I realized you were referring to the subsquadra
but I was wondering if you have to build something to industrialize the product
because solutions are different
maybe your piece in one place must have a corner of puff
would be the top of the rings at 90°
Thank you
Thank you
I don't have to make any pieces.
It was my curiosity.
Thank you shiren.
