When it comes to the thicknesses I already have all the layers ready, but the point is how to indicate precisely the point of the curve because so I don't know how it is realized.. .is already listed. What is there to understand?
system side contour and quota lines can not be equal otherwise you do not understand anything. standards specify the technical design standard
I do not know how to quote precisely the crucible that tells me the center of the circle that is not tangent to the parts but bigger.. .When it comes to the thicknesses I already have all the layers ready, but the point is how to indicate precisely the point of the curve because so I don't know how it is realized.. .
However, my dilemma is whether you understand everything or not... (I made the quotation, that’s why I have doubts)I do not know how to quote precisely the crucible that tells me the center of the circle that is not tangent to the parts but bigger.. .
Then use them.when it comes to the thicknesses I already have all the layers ready,
His name is radius centerthe point of the curve
bigger what?center of circle that is not tangent to the parts but bigger.. .
to understand if the drawing is clear you have to look at it internally.My dilemma is whether you understand everything or not
All right, thank you and good dayThen use them.
His name is radius centerbigger what?
However if you have to quote that center use the klinear quotas... Where's the problem?
perfect, very kind, thank you all!?to share a piece well means first of all to know how it is realized, with which instrumentation and technology, and to put itself in the shoes of those who realize it trying to find missing or wrong information.
personally more than quotating the radius center (we try to use the correct terms) I would quota the height and width of the processing.
there is also to say that a lather with experience often understands missing information but it is good to think that the piece should make it a child![]()
Thank you again! Good evening to alla little design normshttp://www.mauriziogalluzzo.it/dispense-e-materiale-didattico-per-il-disegno-tecnicothat radius is obtained by interpolation of the tool that moves from the point where the quota 4 is located and reaches the final point. so these points should be quoted.
the center only serves if the piece is not circular and processing is carried out with a radius mill 16
