[draft] Updated calculated fields
cacciatorino
I have a draft where a cyclogram of a mechanism is drawn. quotas have a double angle/time notation, in which time is the result of a mathematical calculation performed in the variable table.
I can't get two things:
1) when I change the speed of the machine (expressed at the top right) the update of the times corresponding to each phase does not instantly update, but I must give the command "show all formulas" and then return to "show all values" so that this happens.
2) now to insert the speed variable, I invented the system of a segment that is long so many mm how many cycles per minute of the machine and have known it. modifying the length of the segment by changing the share of the design.
is it possible to insert a casellin in which to edit this value as if I were in excel, without the make-up of the segment? the reason is to facilitate the reading of the file to my interlocutors without opening the variable table.
I use v18 and I have no excel.
