draftsight e dxf
  • Thread starter Thread starter guyver
guyver
hello to all
I have a problem with draftsight,
I would like to know if it is possible somehow to export only a selection of a drawing in dxf
as with autocad you can do in the dxfout command menu.
You could try writing a block on files. in autocad and therefore I presume also in draftsight is used mblocco in the Italian version and wblock in the English version; However, once you have given the command, you can select the drawing part that interests you, and at the time of the rescue, just select the dxf format.
p.s.
I have no draftsight installed and therefore I am not sure of the command name.
