draw a curved staircase in 3d
stefy84
I would need help to draw a 3d scale curve, my problem is the side walls that accompany the steps and then go up with the staircase
I'll give you an image.
I would use the loft command...but it comes to me to cry to think how much all this (decisously complicated in autocad) is supermodo banale with a bim product like revit :frown:
Oops,....
My name is stefania, I am of roma and stopreparando thesis of graduation.
thanks cmq for the answers, I use the 2011 version of autocad,
I tried with loft and managed to draw the walls, but despite asking to have a solid I'm created a nurbssurface that I can't turn into solid, as you do.
try to build curved walls directly with solids, how to build a pipe in short!
I solved it with the thickening command by applying it to one of the two nurbsurfaces generated with loft. thanks
hi sn alby and I would like to know how to make a curved staircase with autocad 2012 in 2d and in 3d
grz hello
